Hole in Oil Filter -- 2019 F-150, under 33,000 miles
Old Oct 23, 2021 | 08:53 PM
Vision.Puller's Avatar
Question Hole in Oil Filter -- 2019 F-150, under 33,000 miles
-Today, Saturday, out of state, Oso Blanco found oil splatter on the F-150 tailgate and elsewhere, then discovered a hole in the truck's oil filter. Oso travels on paved roads, highways, and, rarely, on gravel roads. I had the oil changed at a Ford dealer about 3000 - 4,000 miles ago.
-What causes a hole in the oil filter? Oso doesn't recall impacts to the truck that could put a hole in the oil filter.
Weirdly, my 2018 Ford Explorer lost its oil due to hole in filter at about 2000 miles--about a 1.5 months after I bought it new. Again, I did not observe any action or impact that may have put the hole in the oil filter. We've never experienced oil filter holes before these two incidences, and computer searches have yielded nothing.
Thanks for any assistance.
Old Oct 24, 2021 | 06:22 AM
A few questions,
Where on the filter does the hole appear?
Does the filter can show any sign of excessive pressure like bulging?
What is the name of the filter manufacturer?
Old Oct 25, 2021 | 02:12 PM
Okay, Oso said it looked as if there was a bubble on the oil filter, and there was oil there and everywhere. Once the filter was taken off, did not see signs of holes etc.
This morning, at Ford Dealer, the filter and gasket looked okay, too. Attached are photos.
Next step (hope this is the best step) is to change oil/filter and clean undersides to detect possible leak.
Old Oct 27, 2021 | 04:55 AM
raski's Avatar
If it is a hole, likely a rock or some projectile flew into the filter puncturing it. If the can is bulged out or the seam blew out, excessive oil pressure from an oil pump problem likely caused it. What I am concerned about how much oil leaked out. Hopefully little so any engine damage did not occur. Sadly, the oil pressure gauges are not actual pressure gauges but "idiot" gauges connected to a switch. The gauge will deflect and show pressure with as little as 6-7 pounds of pressure. Hardly enough for an engine running at 2-3000 rpm's.
George L Mason
Jan 8, 2022 06:46 PM
20roadking11
Jun 20, 2020 03:36 PM
Smoothboy2
Oct 10, 2019 09:38 AM
Mary Childress Raines
Nov 26, 2013 10:31 AM
bandit1948
Oct 2, 2012 03:33 PM
