Old Sep 18, 2023 | 05:30 PM
Jhediger78's Avatar
Default Transmission
Hi,
I have 2015 F150, 2.7L v62.while driving my truck would go from 1st to 3rd and stays at 3,000 and will not shift to 4th, also the truck bogs down. I have gotten the truck transmission flushed and they found no metal shaving in the fluid. Has anyone seen or heard of this? And what may I do to solve the issue?
Old Sep 18, 2023 | 05:40 PM
Did anybody check to verify the solenoids are all in working order?
Old Sep 18, 2023 | 06:23 PM
Jhediger78's Avatar
I have not checked those yet.
Old Sep 20, 2023 | 10:14 AM
Make sure you check for corrosion including the plugs outside the trans.
Old Sep 23, 2023 | 06:08 PM
Jhediger78's Avatar
the check engine came on and I had the code ran. PO715 Turbine/Input Shaft Speed Sensor Circuit. Can anyone give any pointers to change this out? Or is this sensor inside the transmission?
Old Sep 23, 2023 | 06:32 PM
If you look a little closer , it does not specify the speed sensor, but the circuit. This includes checking all the wiring to the trans for any corrosion or damaged wiring or connections. Always pays to check the simple things first.
From the sticker on the vehicle what is the trans code -letter or number?
OSEric
Apr 27, 2023 07:30 AM
Bmac43
Feb 17, 2023 12:52 PM
Raffy
Sep 4, 2022 12:47 PM
ITAngel
Oct 5, 2021 08:23 PM
nmdoc
Jun 10, 2014 06:07 PM
