F-350 issues.
Old Sep 9, 2008 | 03:24 PM
rckstr's Avatar
Default F-350 issues.
We have a 1997 F-350 4 dr long bed. It ran great and was very strong. Last year, we were delivering firewood and as we were going down a back road (35-40mph) The truck sputtered a couple times and then stalled. It never started back up. Since then, several diesel mechanics have looked at the truck but has no idea why it wont start/run. Does anyone have any advice?
Old Sep 9, 2008 | 04:45 PM
Default RE: F-350 issues.
Has the cam position sensor (CMP) ever been replaced??
There's an open recall running from Ford for a new unit..The injectors won't fire unless a tach signal is seen by the PCM/IDM (trucks computer, and injector driver module).. Could be other reason's, but the CMP is a major reason for 7.3 stalls..
Old Sep 9, 2008 | 05:37 PM
rckstr's Avatar
Yes it has been replaced. But not by Ford. A local diesel mechanic replaced it. May need to be replaced again.
Old Sep 9, 2008 | 06:12 PM
Possibly,,, and if it is the cause,, you can/will be reimbursed by Ford for the old CMP's plus labor if you can producea receipt/s.. Your mechanic should have a scanner with the capability of looking into the trucks 'data stream'.. There he'll be able to see if the CMP is producing a tach signal, as well as to check thatthe much needed high pressure oil(500lbs min) to fire the injectors is spec for a startup..
The way these engines start is,,,
The engine 'must' crank at a 'minimum' of 100 RPM or it won't start..
The HPOP (high pressure oil pump) must be able to build 500lbs of pressurized oil for the injector 'push'..
The PCM needs to see a tach signal for the injector driver module to energize/fire the coil/solenoid side of the injectors.
There has to good fuel pressure and volume (might want to check that).
Also, on ocassion the fuel heater inside the water seperator/fuel filterbowl will short out and blow the PCM fuse causing a no start condition..
Old Sep 9, 2008 | 08:19 PM
rckstr's Avatar
Sounds like I just need to take it to the Ford dealership. I just wonder how much they will charge to even look at it?
robf350truck
Mar 28, 2012 06:06 PM
VITT08
Dec 31, 2007 07:21 PM
geadam
Aug 20, 2007 10:21 PM
Sledgehammer
May 22, 2007 10:41 AM
Nik_Never
Jan 15, 2007 10:39 PM
