No Heat
Old Mar 5, 2018 | 06:45 AM
2006F500's Avatar
Default No Heat
Hi First time here i have a 2006 ford 500 SEL AWD 3.0l i have no heat antifreez was low took a gallon to fill the tank and i ran to car for about an hour to warm it up and still no heat and the hoses are cold the fan kicks on and the temp gauge took forever to get to normal range any help would be great thanks in advance
Old Mar 19, 2018 | 05:36 PM
2006F500's Avatar
UPdate got heat now found out it was air in the hoses bled it out and all set
Old Mar 19, 2018 | 07:25 PM
Thanks for the update.
Do you think it would be a good idea to find where the missing coolant went?
You might consider this a sort of warning that something is leaking. Unless you already checked it and found the answer.
tattooed_drew
Apr 6, 2020 10:59 AM
ricknags
Apr 5, 2019 02:39 PM
Use Common Sense
Jun 25, 2016 01:30 PM
joshua.donelson
Sep 27, 2005 08:03 AM
wallygator
Sep 11, 2005 01:08 AM
