Crank no start problem
Old Mar 25, 2024 | 05:54 AM
  #11
Tina barber's Avatar
ok, we seem to have a fuel supply problem.
Do you hear the fuel pump run for the 1-2 seconds when you first turn the key on? Yes/no ? If no, recheck work with fuel pump installation power and ground check also.
If yes,check for power to injectors (12 volts) with the key on. Yes/no ?
Did you check the inertia switch for being tripped ?
i didn't have time to check the inertia switch yet sorry for the late reply.
Ill check it today at lunch and let you know what my findings were. Thank you for trying to help.
Ill keep you posted
Old Mar 25, 2024 | 05:55 AM
  #12
Ill keep you posted
Also how do I check the injectors
and yes the fuel pump is making a sound when cutting the key on
Old Mar 25, 2024 | 02:31 PM
  #13
Unhappy
Because the OP did not get back to us to say one way or another maybe he fixed it , don't know.
I reset the fuel reset button and I did the INERTIA button still no crank how do I blow the injectors out and when I put the fuel pump on and if I didn't blow the injectors out could that be stopping it from cranking
Old Mar 25, 2024 | 08:02 PM
  #14
When someone says my vehicle won't start I should have asked , Just what does it do?
It was my mistake for not asking that question and sent you on a wild goose chase when it was not necessary because I assumed the engine was able to crank over ,but just did not fire up and start running.
As I now gather, it does not even crank over to start ,Is this what is happening?
Old Mar 25, 2024 | 11:43 PM
  #15
John Sahil's Avatar
It sounds like you've covered a lot of bases already. Since you've replaced key components and verified fuses and relays, it might be worth checking the ignition switch and the crankshaft position sensor. If those are fine, a diagnostic scan might reveal any hidden issues.
Old May 23, 2024 | 10:15 AM
  #16
Could the problem already be corrected since we did not hear from Tina for quite a while?
Old May 25, 2024 | 04:02 PM
  #17
On title crank no start. At post # 13 no crank no start then that's different diagnostic procedures.
Problem corrected or not, everytime there is no followup from thread starter is bad to this forum, the entire community, as well as the entire world who come to this thread from search engine result.
Annamaytru
Oct 16, 2021 03:57 AM
Vaughn
Nov 29, 2020 10:33 AM
D1995
Nov 6, 2019 02:30 AM
Huntress2u
May 12, 2018 04:16 PM
dhard
Oct 4, 2010 09:44 PM
