Ford Freestyle The new crossover, combining the versatility of an SUV with the compact size and feel of a station wagon.
Flyee pressure regulator no vaccum line attached
Old Nov 30, 2024 | 11:10 PM
Tocker247's Avatar
Default Flyee pressure regulator no vaccum line attached
I just was recently given a 2005 ford freestyle upon looking at a coil pack for a cylinder 4 missile i noticed there is no vaccum line to the fuel rail pressure regulator. Where should this vaccum line run to and connect to on th
e engine as it's no where to be found as hose wise?
The cylinder 4 misfire just started after I changed tge fuel filter I'm thinking some debris may of been dislodged n may of clogged an injector for cylinder 4 but I rearranged the could as a test for tomorrow's drive to see if by my luck a coil went bad at tge same time. I'll probably try my loud light set on it tomorrow n check all of it. But figure the filter fuel was near black coming out of it.
Last edited by Tocker247; Nov 30, 2024 at 11:43 PM. Reason: Additional information
Old Dec 1, 2024 | 02:52 PM
You need to be careful with Fords concerning misfires.
If there is an ign system problem , the PCM will disable the injector for that cyl possibly sending you on a wild goose chase..
The better thing to consider would be to replace the fuel filter again and see what comes out of the filter .
What engine is in your vehicle. There is a question of possibly a fuel pressure sensor. Can you supply the engine code from the vehicle sticker on the driver's side door?
2000 Ranger
Aug 14, 2024 08:04 PM
hsbc05
Jul 11, 2019 04:21 PM
crosley
Jul 4, 2018 06:57 AM
MossyOak10
May 18, 2015 04:15 AM
snowballexpress
Jun 13, 2011 11:02 AM
