starting problem
can u bypass security on 2000 taurus when starting...the issue is the keys was replaced and transponder and still having a starting problem. mechanic thinks it has something to do with the security system build in the car. any help and I would be very grateful
As you know when you first turn the key on the theft lite should come on and turn off as part of the bulb check phase.
If a theft attempt was made or there is a system fault the lite flashes or stays on steady for 60 seconds.
The system's functionality is contained in the PCM. I guess you have a choice of either accepting it as it is or have someone with a capable scan tool get in and check it out.
