Distributor
Old Feb 14, 2022 | 05:06 AM
Tea bag's Avatar
Default Distributor
Distributor, what's the tube at the base of the distributor called my new didn't come with it
Old Feb 14, 2022 | 05:34 AM
What is this dist for?
Model, size engine, year are all important , unless you can post a picture.
Old Feb 14, 2022 | 05:37 AM
Tea bag's Avatar
78,f150, 300 inline 6
Old Feb 14, 2022 | 05:39 AM
Tea bag's Avatar
Default Distributor
It's on a 78 f150, 300 inline 6
Old Feb 14, 2022 | 05:54 AM
Without a pix, not sure.
Is this the vacuum advance unit that is held on to the side of the dist?
Old Feb 14, 2022 | 05:57 AM
Tea bag's Avatar
Default Distributor
Yes,it is
Old Feb 14, 2022 | 10:04 AM
OK, then all you need to do is, remove the clip that holds the arm from the vacuum advance unit,, then remove the 2 screws that hold it onto the dist and now install that unit on the new dist.
3 steps, install 2 screws, connect the arm to the pin , install the retainer clip , and you are good to go.
Did you mark anything so you get the dist in correctly ? If not, unless you know EXACTLY what to do, you could get into deep waah- noo na !
That dist tells the plug when to fire and if that is not set correctly on installation , the wrong plugs could get the spark to fire at the wrong time and the engine may not even start and could backfire out the intake or exhaust.
RacingRoger
Apr 2, 2021 10:13 PM
camshaft01
Dec 24, 2008 03:16 PM
trex66
Feb 10, 2007 10:07 PM
barkerjoe
Nov 17, 2006 11:19 PM
blue_streak
Apr 8, 2005 03:24 PM
