Need advice on my Ranger
Old May 19, 2016 | 02:50 PM
wouldsy's Avatar
Default Need advice on my Ranger
I have a 1994 Ford Ranger and when it rains, water leaks under my hood and wets my ignition module. Then my truck won't crank until it dries out completely. I keep a plastic bag over it when I'm not driving it but this is no help when I have to get to work in the rain. Is there anyway that I can cover it for good, that would not melt? I hope one of you knows how to fix this.
Thanks
Old May 20, 2016 | 11:41 AM
Alanah_Rae's Avatar
welcome on a board !!
Check out this maybe its help !!
Old May 21, 2016 | 07:47 AM
A good part of the time when moisture causes problems it is because there are poor connections to start with and the slightest bit of moisture can cause a voltage drop and the circuit will not work. It might be a good idea to thoroughly check all the plugs and connections for corrosion and apply some dielectric grease (available at most auto supply stores) to prevent moisture intrusion.
staticxdeath
Mar 29, 2008 10:45 AM
kooter07
Dec 28, 2006 11:19 PM
kooter07
Apr 9, 2006 07:16 PM
bkito
Sep 2, 2005 01:34 AM
ricekiller2003
Apr 21, 2004 09:03 PM
