No tail lights on 86 F-250
Old Sep 5, 2018 | 01:30 PM
DeltaRed16Echo's Avatar
Default No tail lights on 86 F-250
I recently bought a 1986 Ford 250 with a 6.9 diesel. What I just found out on the way back from camping is that I have no tail or navigation lights. How would I go about fixing the problem?
Old Sep 5, 2018 | 01:44 PM
You can"t always use a test lite for checking on newer vehicles, but you can always use one to check fuses and for power to certain areas.
If you have one great, if not I would suggest investing in one because right now the first thing you need to check with the lighting problem is the fuses.
You just connect the ground clip of the test lite to a good ground and proceed to place the test lite probe tip on each side of the top of a fuse. If it lights on one end , it should lite on the other side also. If not, simple, the fuse is open and needs to be replaced. This takes about 1 minute to do maybe less depending on where the fuses are located.
If the fuses are all confirmed good, now you need to start tracing wires from the light switch to the tail lights You can also use the test lite for this.
Old Sep 11, 2018 | 08:01 PM
I have already tested the fuses and they all work. I also tested the tail light wires on the back of the truck. There was no power on them.
Old Sep 12, 2018 | 03:13 AM
I believe now you need to confirm power is coming out of the headlight sw . You can remove the switch by pulling out the switch stalk and depressing the little button on the bottom of the switch and removing the **** , then the switch retaining nut, (bezel) . Now the switch is accessible to do your testing. Just remember the headlights will be on while you are doing this and if you need to do something else you can always push the switch stalk (****) back in to shut the lights off until you are ready to continue.
The color of the wire that is supposed to have power at the rear tail lights should also be that color at the switch .Confirm power is coming out of that wire, which I believe comes thru the door pillar down the back of the cab and then thru a connecting plug then on back to the rear of the vehicle.. If that color wire is there confirm it still has power going out of the vehicle and work your way back confirming power is available until you get to the point where you lose it It could be at the rearmost area, but you need to confirm every section and you will eventually find the break.
When you probe the wire you should apply liquid tape over the opening to prevent corrosion from having a place to start.
I would never enter any off color or crude language and can only hope the asterisks are the procuct of a computerized program.
Old Sep 21, 2018 | 12:22 AM
Default No brake in the wires
I went online to a website and found something very interesting. Turns out that the mechanic that owned the truck before the guy I got it from did not have a Ford truck electricians license. So I fixed the problem and I now have tail lights but they go off when I turn the head lights on. Any ideas what the problem is?
Old Sep 21, 2018 | 11:14 AM
It would probably be a good idea to know what you did to get the tail lights "working".
Not knowing that just throws more mystery into the problem.
Did you do the checks suggested on my earlier post?
Old Sep 30, 2018 | 12:37 AM
Yes I did and what I found was that half if not all the switch wires were not in the right spots. Even though I now have parking lights they still go off when I turn on the headlights. Can not figure out why they do that.
Old Sep 30, 2018 | 12:55 AM
I don't remember if the parking lights (front) always stayed on with the headlights on , but if that is what you want just hook up the parking lights with the tail lights which go on any time parking or headlights are on. There was a plug that went on to the headlight switch, was that plug removed and wires attached individually? I should have a diagram for that system , will have to check.
madmanadam
Jul 17, 2017 08:21 PM
ba_50
Feb 26, 2016 02:57 PM
hyp05fxdl
Feb 12, 2013 10:14 AM
fordka
Nov 12, 2011 10:18 AM
RetiredNavyGSCS
Feb 2, 2011 05:52 AM
