Help with my F-150 2008
Old Aug 9, 2025 | 02:15 PM
  #11
Now I need some help,,,,,,what do you mean by slurping ?
If we spray a very small shot of starting fluid , it either tries to run or knocks and does nothing else .
If it attempts to run, we have a fuel supply problem which could be injectors, fuel supply , or fuel pressure. Just because the pump runs does not mean it is delivering fuel at the required pressure.
The only right way to check the pressure , IS WITH A FUEL PRESSURE GAUGE . Everything else is guessing and that can be costly.
Old Aug 9, 2025 | 02:21 PM
  #12
TiffLem's Avatar
Could it also be the pressure sensor?
The engine started running with the starting fluid but as soon as we stopped spraying nothing happened anymore.
Old Aug 9, 2025 | 02:31 PM
  #13
YES !
The pressure sensor when operating correctly sends the pressure info to the PCM which sends pulsed power to the fuel pump driver module to maintain a steady required pressure. It is time to bite the bullet and get a gauge there to see what you have or don't have.
Old Aug 9, 2025 | 04:23 PM
  #14
TiffLem's Avatar
My partner took out the fuel pump, and the hose on the pump that sends fuel was completely disassembled... 🙄
Old Aug 9, 2025 | 04:42 PM
  #15
Thank you for the update.
Makes you wonder about the place that installed the replacement pump.
The pump doesn't come with a new pick up hose/ line and if not secured properly this time, it will come off again.
Dropping a fuel tank , especially if with a full tank of gas, is no fun.
Old Aug 10, 2025 | 08:02 AM
  #16
TiffLem's Avatar
My partner put a cable tie on it, but it's possible it could happen again. It took him 30 minutes to assemble/disassemble it, but it's no fun either!
Old Aug 10, 2025 | 08:28 AM
  #17
Thank You for the update !
Bdunph542
Dec 31, 2022 01:25 PM
Sleepycowboy87
Jul 3, 2021 10:13 PM
Tim Gibbons
Jan 8, 2017 05:04 AM
TrueBlue72
Dec 22, 2013 06:46 AM
xoxosaffron
Nov 20, 2009 04:48 AM
