Clutch pedal has 2 inches of travel before moving pushrod
Old Feb 12, 2023 | 07:08 PM
  #11
hellothere's Avatar
Thank you for the advice! Hopefully it doesnt get to that point.
I bled the clutch master, reinstalled, and same issue, pulling unlimited amounts of air, so its got a leak. I most likely damaged the hose pulling off the first one.
If I do end up having to pull it, ill definitely change all those parts, so I wont have to worry about it in the future. projects do grow like that dont they lol
Ill keep you updated!
Old Feb 18, 2023 | 08:49 AM
  #12
hellothere's Avatar
well, the system is indeed not holding a vacuum, no visible leaks on the line.
holds vacuum up to about 20 then lets in all sorts of air.
I guess to change the slave cylinder, you have to drop the trans, so unless im missing something, thats the plan.
Old Feb 18, 2023 | 10:09 AM
  #13
hellothere's Avatar
I never touched the bleeder valve, decided to make sure it was snug. turned it, it wasnt very tight, gave it a little more to snug it up, and the whole bleeder portion of the slave cylinder snapped. Guessing it was cracked and causing the leak, I didnt put enough pressure to break the amount of metal there is.
texashobo
Dec 12, 2014 05:10 PM
skid2964
Sep 27, 2009 02:29 PM
fordprobation1
May 12, 2008 02:09 AM
DoUgLaS
May 19, 2007 09:21 AM
Range96
Aug 13, 2005 01:58 AM
