Focus Blower Motor won't work
Old Jul 28, 2013 | 10:29 AM
HocusFocus's Avatar
Default Focus Blower Motor won't work
Can anyone help me determin why my blower motor on my 02 Focuse SE won't work at all.
I've looked in the Haynes repair manual and it is not very clear where the fuse is. According to the manual I THINK, it's a 7.5amp fuse of which I've checked all that are in the inside of the car. Also checked all the fuses under the hood, those all look good.
Any help would be greatly appreciated.
Thanks
Old Jul 28, 2013 | 09:44 PM
bluewind's Avatar
Check the switch in the dashboard, check the resistor, and check the blower relay if it has one.
Old Jul 29, 2013 | 05:22 AM
GilbertF's Avatar
I had same problem. I ended up replacing both the blower motor and resistor. All has been great since then.
Old May 2, 2024 | 08:43 AM
asik's Avatar
Hello guys, I have similar problem on my Focus mk2.5 1.8tdci from 2008. My engine blower does not spin even with AC on. I checked that the blower does have the DC supply - it was ok (the diagnostics said something about circuit low - this DTC was introduced with some longer full gas). Then I checked the signal cable from ECU and it does not prowide any PWM signal (I checked the cable in the fuse box with an osciloscope. Previously the thin blue cable was disrupted, so that is why I check in fuse box) Any idea why the ECU does not send any PWM signal? Or have I missed anything else? Thanks for your help!
Old May 3, 2024 | 08:14 AM
Be aware Ford does not usually have components grounded and provide power to make some motors operate.
The power is always there and the switch(s) provide the ground..
You may need to start at the switch to verify it is in good working order . If OK, remove the blower motor assy, (a few screws) provide power and ground to the motor itself .
It will either work or it will not. Depending on what you get will determine where you go from there.
apollo
Dec 4, 2023 01:20 AM
Warhawk68
Aug 11, 2011 02:41 PM
KrisB
May 11, 2010 07:47 AM
PJMZ28
Aug 10, 2007 09:23 PM
David Mason
May 27, 2006 08:20 PM
