2006 Bounder Triton V-10 motorhome
Old Jul 7, 2025 | 09:27 PM
  #11
Good, can you find out if you have 4WD or 2WD?
If you have 4WD you can select the mode with a toggle switch or button to switch between 2WD or 4WD mode.
Old Jul 9, 2025 | 04:25 PM
  #12
scubakerny's Avatar
2WD and automatic
Old Jul 9, 2025 | 11:08 PM
  #13
The PDF files below are huge and difficult to navigate here's the 3 index pages:
Don't know you have auto or manual hvac, Vacuum-Auto_HVAC.pdf and Vacuum-Manaul_HVAC.pdf are under "vacuum and vapor hose diagrams" so they are also included within the huge Diagrams-ALL.pdf, I pdf-generated them separately so they are easier to navigate and follow.
Above is the emission control, if you need any info on subsystem/component on the right side, let me know. I can't print pdf all of them, has to be done individually.
If you have any symptoms like hvac or lack of power when climbing the hill or a CEL or DTC (because of evap or egr) or braking problem (because of brake booster), you can narrow it down further.
Old Jul 10, 2025 | 01:54 PM
  #14
scubakerny's Avatar
Awesome, will review. Thank you so much
Old Jul 11, 2025 | 03:40 PM
  #15
scubakerny's Avatar
Appears the black hose is labeled 14 on this diagram, coming from a vacuum source. Now to chase down that vacuum source
Old Jul 12, 2025 | 12:53 AM
  #16
So you are saying just the vacuum source. That 14 gets vacuum from intake manifold, no question about it, but does it go thru a tee, and where that tee is. Try to trace the hose from the brake booster.
Attached below a PDF of intake manifold removal and install, it's probably near the rear closer to the firewall.
Snapshots of intake manifold removal shown below, I tried to enlarge the best I can:
jojagard
Apr 18, 2024 08:13 PM
Keelan4604
May 3, 2023 09:41 AM
Humer
Dec 5, 2021 10:48 AM
Xandersmom2007
Jun 9, 2021 07:55 PM
Van Wilder
Nov 29, 2020 10:35 AM
